Boring the B16a??? what will the outcome be?
I've been hearing a lot of people boring the LS motors but i hardly ever hear about boring the B16a. I just had a few questions.
*what the safest that I could bore it out to?
*I was thinking 84mm. IS that too much?
*how much hp & tq should i expect to make on a stock B16a motor I.H.E ...........
if bored out to 84mm?(stock compression)
Planning to get GE sleeves.
any insite and coments are welcomed. Open to all possiblities
please tell me how i would be hurting the R/S ratio? WTF
IF i understand it right it would not affect the frition & pressure amount on the sleeves at all. Am I right on this?
that is why i ask questions here. so that i may learn befor i act.
[Modified by ill phil, 3:17 PM 11/12/2002]
Once sleeved you can safely go up to 84.5mm bore if you plan of FI and even larger if you plan to stay NA.
(pi)(radius)(radius)(stroke)(# of cylinders)=displacement
84.5mm bore=42.25 mm radius for the bore=4.225cm
(3.14159)(4.225)(4.225)(7.7)(4)=1727.24........
The increase in torque and hp is roughly equivelent to the increase in displacement.
1727.24-1595=132.4
132.4/1595=.082
So by my math thats roughly 8% more hp. The real gains would come if you went FI with the added boost that you would be able to run with sleeves, rods, and pistons.
[Modified by racerxadam, 4:33 PM 11/12/2002]
[Modified by racerxadam, 4:37 PM 11/12/2002]
1727.24-1595=132.4
132.4/1595=.082
goldegg
Nov 11, 2006 09:06 AM
