Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Hard time bleeding my clutch. 2002 Civic Lx
Old Mar 17, 2018 | 12:12 AM
Jhauoli's Avatar
Default Hard time bleeding my clutch. 2002 Civic Lx
Can anyone give me some info. I just changed out my clutch master cylinder. After i installed it. I tried to bleed the line. There is no pressure in the peddle and the slave doesnt move. I tried vacuum bleed. Gravity and reverse
bleed. And still theres nothing. The peddle goes all the way to the floor and its stuck it doent retrack or anything i must have wasted a whole bottle of fluid. I took off the slave broke it down cleaned it and put it back together. And installed it again. And it still has no pressure when i tryd bleeding it.. Does anyone have any idea on what i need to do. The clutch master cylinder is brand new. So ahould i replce the slave with a new one. And change out the line.. Or should just blow up the car to hell.
Old Mar 17, 2018 | 05:57 AM
toyomatt84's Avatar
Sanji
Default Re: Hard time bleeding my clutch. 2002 Civic Lx
Did you bench test the master cylinder before installation?
Old Mar 18, 2018 | 08:04 AM
killer_Bseries's Avatar
Use a vacuum bleeder @ the slave cylinder and while pumping push the shift fork toward the slave and hold it. Also have someone pump the peddle too while your pumping. I had the hardest time bleeding my em2, never have I had such a hard time bleeding a civic clutch. I was in same boat as you. Good luck.
R81_DC2
Aug 14, 2009 08:54 PM
obuhmyuh
Apr 19, 2008 02:14 PM
Panoply
Jun 19, 2006 06:45 PM
InspiredRacer
May 19, 2003 09:39 AM
AndyD
Mar 5, 2003 08:32 PM
