Honda S2000 Honda S2000
99 honda s2000 engine cuts out at 7000RPM
Old Mar 12, 2018 | 01:35 AM
rizzll99s2k's Avatar
Default 99 honda s2000 engine cuts out at 7000RPM
Engine is cuting out on my S . Car is warmed 3 bars, did the map wack, cleaned the IACV.......... oil is full. Replaced the Vtech solonoid gasket and everything was fine. Just all of a sudden it started doing this..... MAP sensor is also cleaned ... the place it goes in is also cleaned. Read all the forums every where..... did everything suggested ..... Car is stock with only 62K miles. ..
please Help
appreciate any info ...
Old Apr 1, 2018 | 09:39 AM
yamaha6611's Avatar
Default Re: 99 honda s2000 engine cuts out at 7000RPM
Does the vtec engage between 6,000 and 7,000rpm?
Old Oct 25, 2018 | 09:54 AM
Zeshin's Avatar
It can be either a problem with air, fuel, or spark. You should try and check to see which area your problem is occurring. I had a similar issue with my engine cutting out completely at 6k RPM, and it turned out I had a bad coil pack plug on the harness that was causing an intermittent/weak spark in one cylinder.
MyWhiteEJ6
Mar 21, 2015 10:48 PM
AedanM
Nov 2, 2009 02:23 PM
TypeR324
Honda S2000
Jan 19, 2007 03:50 PM
WRS2K
Honda S2000
22
Jul 2, 2005 07:33 PM
mickfred
Honda S2000
Jul 12, 2004 09:06 AM
