Sol brakes on integra trailing arms
Will my 1994 del sol rotors and drum brakes fit on these 1997 integra trailing arms without rotors or calipers?
Reading old posts has turned my mind to mush
But I am thinking I might just put the del sol si disk brakes on the integra trailing arms I am putting on. I'm not sure.. I'm looking for an affordable disk brake option since I have the integra trailing arms.
youre confusing.
you are asking contradictory things. thats why youre the one confused.
integras never came with drums. only with disc brakes. so what are you talking about rear drums?
and what year integra are we talking about?
what car do you have? what parts do you really have?
I have a Honda del Sol stock 1994
i purchased 1997 integra trailing arms.
I want to add disk brakes that will not effect stock rim size of 13_14 for the del Sol.
you can put the integra trailing arms on the del sol (with drums).
the rear rotor and caliper is the same across all EF/EG/EK/DA/DC that have disc brakes.
there are very slight differences in the trailing arm itself, but likely wont have any issue. the biggest issue is finding a e-brake cable that works. you probably just need del sol Si cables, since it came with rear disc brakes.
you will not have an issue with 13" wheels.
De_tour
44
Feb 1, 2008 10:49 PM
seanc520
Feb 16, 2006 01:26 AM
