DelSol suspension question
I have read the faq's but wanted to ask a more specific question.
I have a 94 del sol S, my trailing arms were toast due to rust and I upgraded to 97 integra trailing arms.
I am new to working on my cars and just wanted to keep the transition simple as possible.
What brake setup would be the easiest in the rear with the integra trailing arm? I don't think I can just put drum breaks back on because it is a disc break setup on the integra. Can I just put the rotor and caliper setup from another civic? What year? I would like to keep the m/c and all the lines stock del sol if possible.. Though I will probably be replacing them all in the rebuild. I am not interested in any big break build.. My motor is del slo
talks to himself
Re: DelSol suspension question
Civic/Integra Disc Brakes. The trailing arms didn't come with calipers and rotors?
Check 'em again. If the Integra RTAs came with rotors and calipers, buy integra flex lines and see how the MC/PV feel with the discs in the rear.
I swapped the MC and PV on mine when I did the conversion but I also swapped large front brakes.
First off thanks for the reply.
Due to weight I had just ordered the arms (without rotors or calipers) and had them shipped out east from Oregon to avoid rust issues I have here with part foraging in NH.
I will have to look through the faq's again for info. I was hoping I could just put drums on this integra control arm since there isn't any hardware on it.. Just the part with the four bolts, that rotates.. Errr I'm not sure what its called..hub?...
I am rebuilding the entire suspension and brake setup due to rust. The rear end suspension and brakes are my first attempt at wrenching other than oil changes. So I appreciate the response.
phantom_sol
10-07-2003 01:56 PM
