Honda S2000 Honda S2000
Cluster pinout 2004 vs 2006
Old Mar 1, 2018 | 05:20 AM
Ser's Avatar
Ser
Default Cluster pinout 2004 vs 2006
Hello friends!
I have an unusual problem. My car is 2004 year releas and it has 2006 or later cluster attched in it. Don`t ask why, i bought it the way it is.
So i`ve got 2004 cluster now in my garage and going to install it.
Problem is... i don`t have wiring pinout from 2006 year to install it properly. Ofcourse i can install it with wiring pinout scheme of 2004 year, but i`m not sure wich harness installed now (rewired 2004 or just oem 2006). It confuses me.
Maybe someone has a cluster pinout of 2006 year releas?
Thank you!
Old Mar 1, 2018 | 08:28 PM
Ryanthegreat1's Avatar
Default Re: Cluster pinout 2004 vs 2006
That 2006+ cluster won't work on a 2004.
The 06 and up went to a serial communication to display the coolant temp, check engine light, charge light, cruise control, and check fuel cap. I believe the this is also when they added the outside air temp.
You would still be able to see speed, rpm, fuel, brake, door and trunk open, blinkers, and high beams.
Old Mar 1, 2018 | 09:03 PM
Ser's Avatar
Ser
Yes, i lnow it ☺
It`s actually doesn`t work. That`s why i bought a 2004 cluster.
But to handle the wiring diffirances i need a cluster pinout diagram of 2006 year.
Old Mar 1, 2018 | 09:20 PM
Out of a 2006 ETM.
Old Mar 1, 2018 | 09:27 PM
Ser's Avatar
Ser
Out of a 2006 ETM.
Thank you soooo much!
Just what i neded.
Celvinchin
Dec 4, 2018 02:39 AM
aziaticvang
Jan 8, 2008 06:41 PM
kcrxxx
Jul 27, 2007 01:42 PM
chadmasterc
Jun 4, 2005 09:42 PM
importboi22
May 31, 2004 10:32 PM
