Integra battery dies after car gets turned off
Old Feb 26, 2018 | 06:50 PM
julio nunez's Avatar
Default Integra battery dies after car gets turned off
I have a 1995 Integra ls and I recently did and engine swap b18 to b18 but my battery now dies after I turn it off and it will only start when it's jumped sometimes it'll barely start right after I shut it off, I replaced the battery and it does the same thing do I have a loose ground ??
Old Feb 27, 2018 | 05:46 AM
CandyRedRC46's Avatar
Default Re: Integra battery dies after car gets turned off
You need to do a current draw test. You need to have a battery fully charged in there and a good multimeter. Then with the car off and one terminal disconnected, measure the current draw through the battery post to the terminal. Check if it is withing spec. If it is above spec, pull one fuse at a time until you find the circuit with excessive draw. Then when you narrow down the circuit in question, you can figure out what specifically is wrong with that circuit.
Old Feb 27, 2018 | 08:12 AM
EnjoyTheRideDC2's Avatar
What did you replace the battery with? A brand new battery or some other used one you're unsure even has enough charge to start up a car?
Old Feb 27, 2018 | 09:16 AM
thewrai6th's Avatar
Alternator is good if you can jump start it. Sounds like just another dead battery to me.
https://honda-tech.com/forums/tech-m...t-car-2366439/
Old Feb 28, 2018 | 04:11 AM
Icon2 Re: Integra battery dies after car gets turned off
My thoughts exactly....
tegboy321
Oct 19, 2020 06:47 PM
ALLDAY-24
Oct 14, 2012 09:56 AM
EGandDArida
Oct 11, 2009 06:42 AM
smash fascism
Dec 3, 2005 07:58 PM
LaOstha
17
Feb 21, 2005 02:15 PM
