Honda CR-V & Element 2WD & 4WD Element & CR-V
How do i remove hatch glass
Old Feb 23, 2018 | 05:41 AM
saltsportsman's Avatar
Default How do i remove hatch glass
I have a 2014 crv that i just purchased that was hit in the rear but the glass is still good but i need to take the glass out of it and save it for the new hatch that does not have glass in it. Anyone that can help me out I would appreciate it.
Old Feb 24, 2018 | 08:05 AM
UK-Kev's Avatar
Default Re: How do i remove hatch glass
The rear screen is bonded into place and you will require specialised cutting tools - I would suggest you get a windscreen fitter to remove and fit the screen.
Old Feb 27, 2018 | 02:11 AM
B20Zer's Avatar
This is the correct answer, it's a mission to do, requires piano wire etc. Get a price from the local windscreen fitter to remove and then refit the glass into the new door, they can cut it out and then refit it to the new door, even cut it out of the old door and then come and refit once the new door is fitted to the car. Do not remove the old door from the vehicle before the glass is cut out, it can be a real pita to cut/a lot of force needed sometimes and it's even harder if the door is loose/lying on the floor.
Old Feb 28, 2018 | 08:47 AM
UK-Kev's Avatar
Here’s a link to how the professionals do and they don’t use piano wire.
Link >>>
jruiz094
Apr 4, 2010 07:16 PM
4drcivicls
Apr 16, 2009 09:00 AM
Toroke
Apr 14, 2006 03:55 PM
thresher
Jan 16, 2005 10:47 PM
*Boostwerks*
Sep 13, 2002 08:52 AM
