Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Swapping driver's seat in 2010 civic
Old Feb 19, 2018 | 08:05 AM
Combat Bob's Avatar
Default Swapping driver's seat in 2010 civic
I'm putting in a replacement driver's seat in my 2010 civic. I ran into an issue underneath with the electrical connections. My current one has four plugs and the replacement one only has two. They said the replacement one is from a 2010. And it looks the same. Except for missing two of the connections. Thoughts on what I can do about it?
Old Feb 19, 2018 | 05:44 PM
97emsedan's Avatar
Default Re: Swapping driver's seat in 2010 civic
Model of Civic to which you are installing the seat? Do you know what model of Civic the new seat came from? The extra sensors might be SRS weight sensors.
Old Feb 20, 2018 | 09:21 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Your Civic has the driver's seat buckle tensioner (aka outer lap tensioner). For example, an EX-L has those on the driver's and passenger side. Those extra connectors in the photo are for the driver's seat belt buckle switch and seat belt buckle tensioner. The other Civic was probably a lower model trim, such as an EX, LX, etc.
See if you can remove the harness clips and wiring to transfer to the other seat and use your existing seat belt buckle.
Example:
EX-L: https://www.hondapartsnow.com/parts-...eat-belts.html
EX: https://www.hondapartsnow.com/parts-...eat-belts.html
Outrun
May 7, 2016 10:10 AM
$i♡myblackem2$
Honda Civic (2001 - 2005)
Nov 24, 2014 10:27 PM
dogmelissa
33
Dec 11, 2007 04:34 AM
electronspeeder
20
Apr 2, 2002 03:24 PM
