crossthreaded 10an fitting on valve cover
Old Feb 3, 2018 | 05:21 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default crossthreaded 10an fitting on valve cover
has anyone here crossthreaded a AN fitting? i have slightly crossthreaded a 10 AN fitting on my valve cover and i would like to see if i can fix it with a die but im not sure what size to use.
Old Feb 3, 2018 | 07:47 PM
Chance EG's Avatar
Default Re: crossthreaded 10an fitting on valve cover
Can you post a picture of it? I've actually had a lot of success in the past just taking a razor blade and running it through the threads to clear them out and straighten.
Old Feb 3, 2018 | 10:17 PM
Old Feb 5, 2018 | 09:21 AM
jim chuck's Avatar
A thread file would probably work. Is cutting the fitting off and welding a new one on a viable option?
Old Feb 5, 2018 | 09:28 AM
AZ_CIVIC's Avatar
Yeah I've just used a little flat head screwdriver to clean it up.
Old Feb 5, 2018 | 11:15 AM
liam821's Avatar
It doesn't hold fluid so I'd probably fix it with a file or a 10an thread die if you can find one and just be really careful threading it back together.
Old Feb 5, 2018 | 11:58 AM
The sweed's Avatar
I have used a lube up -10 steel cap with success..
Old Feb 6, 2018 | 04:53 PM
if i could find the die, i looked for about an hour online, i would use that. but no dice
im going to use a cap and this place in town sales the steel caps. im basically going to force it on if all else fails
Old Feb 6, 2018 | 04:55 PM
i can cut it off but i dont want to use that port anymore. i have four parts of on my valve cover and i want to cap off the back two now. i might just get a steel cap and tie it down with that with some teflon
Old Feb 7, 2018 | 11:51 AM
liam821's Avatar
You want a 7/8" - 14 SAE die. Search amazon for "7/8" 14 SAE die" and you'll find a bunch.
Here is a nice set for $30
Amazon Amazon
Old Feb 10, 2018 | 02:38 PM
https://www.amazon.com/CTA-Tools-825.../dp/B009VIA1EW
thank you! ill have to pick up this set to save this fitting.
RedneckRicer
Nov 13, 2008 12:29 PM
scspeed
Mar 6, 2008 04:02 AM
vtec.dc2
May 6, 2005 01:40 AM
allmotorhatch
Mar 8, 2005 09:46 AM
