B16type r
Uh... a US B16 engine harness will be from a '99-00 Civic chassis and will not plug into a '98 Civic chassis properly. I don't think there is a "plug and play" solution... it will be best to start with the engine harness that came with the car and modify it to fit the B16B.
My answer was simply based upon whether or not the engine itself will still be able to go into another chassis. The answer is YES. If that engine can go into another chassis using the same harness that he currently has, of course, the answer is NO. He asked about the engine itself using some time of U.S. Harness. He didn't express the same year. Just a U.S. Harness.
Yessir. "Hard to find" is an understatement. This is where my thoughts had turned to having a basic harness made by Rywire, WireWorx, etc. Although a bit of a penny, it will be flawless and he can get additional guidance from the people who make them themselves without having to go through a lot of guesswork.
A 96-98 sohc vtec engine harness will work too. There is nothing unique about a b16b as far as sensors go. Over paying for a custom harness is stupid when you can get one for $50 or less locally.
Many of these companies have near-ready made harnesses for this engine, so he doesn't have to chase issues later. But again, OP must decide.
My Integra and dx hatch both use engine harnesses from used cars. I wouldn't second guess a harness I removed myself from a junkyard car. If you were incapable of inspecting a harness before you buy it then I'd be left wondering how you wouid be capable of an engine swap. Anyway I seriously doubt the OP even has a b16b.
That's like saying that someone shouldn't plaster their wall if they don't mix/stir their own "mud" using powder plaster & water, and instead, purchases a tub of the pre-made mud that turns colors to tell you that it's dry and ready for the next coat or sanding. In the end, the wall still got finished, with some time to spare. Meanwhile, all of the other steps still had to be followed in order for the wall to be completed..
Is the person who didn't mix their own "mud" as one of the steps to fixing their wall truly any less competent than the person who did? In the end, did it really matter? I would say no.
You did it in a way that was less expensive in material, but someone's time is always worth something, even if its your own. So, yes, Kudos for you for creating your own wiring harness. But please don't forget, that's a cost that we all have to balance as a decision factor., and sometimes its worth that extra cost to have something right out of the box ready to go and not "create" your own harness.
Apparently, enough people have the same philosophy or there would be no demand at all for pre-made harnesses, and organizations like Rywire and Wireworx, wouldn't exist, and we'd be stuck in 1998 when we had to create jumper harnesses and hacked wiring harnesses ourselves. I for one am glad that this option is at least available. But not retrofiting one doesn't make a person doing this an incompetent person when doing a swap.
IMHO, the OP's situation is no exception to that.
I just had to deal with a previous owners "custom" harness. Ultimately, I had to cut about 10 wires on the dash harness just to remove the engine bay harness and wouldn't be suprised if somewhere in the mess was the cause of my ignition problem.
Just remove the jdm harness and use a 96-98 vtec engine harness, that will at least get it running. Looks like you're missing the map sensor and you'll need to figure out which throttle cable you'll need.
Heh... "only 20"... You a grown man already.. Time to get to work, son.
xxstreetracer605
Jul 9, 2011 05:23 PM
Themouse
May 28, 2009 03:57 PM
project 2two9
Nov 23, 2006 06:11 AM
SkunkCrxSi
Jul 23, 2004 02:49 PM
