Stripped intake manifold nut how to remove ?
I need some serious help I took the head bolts off the head is ready to come off except I stripped one of the nuts it’s literally the only one! Idk what to do the pistons are covered in anti freeze I’m ready to replace the gasket but I can’t because of that 1 stripped bolt I don’t have enough room for the socket wrench and the other wrench I have the ringed end makes it worst so I stopped touching it. How bad is it?
Doesn't look like it's stripped too bad. If you can fit a 6 point socket in there it will probably work. Otherwise use a small pair of vice grips if possible.
Worst case you remove the head with manifold attached and deal with it off of the car. If you do that, put some of the other nuts back on so it is not hanging by one point.
But yes, 6 point socket. Try one slightly smaller than 12 mm such as 7/16 or 11 mm. Use a hammer to tap the socket on lightly if needed. Make sure it is all the way on the nut before trying to turn.
There is also stripped nut extractors that will bite into the marred heads of nuts and bolts.
They look like this:
Mastercraft 6-pc Bolt-Out Damaged Bolt/Nut Remover Set | Canadian Tire
Mastercraft 6-pc Bolt-Out Damaged Bolt/Nut Remover Set Canadian Tire
Had this problem. Can't use a torch since the intake manifold is plastic. Although it's rated to be used in an engine so is presumably heat resistant. That nut is impossible to get to with real leverage. I used a TWENTY INCH air hammer chisel, held firmly with my opposing hand to aim it at the left side of the nut. It took several minutes but finally came off. Had this not worked, I would have continued until I split the nut and would have pried it off. This experience taught me that specialty nut splitters also exist.
B_Swapped93
Dec 2, 2013 08:14 PM
Tuneman1984
18
Sep 19, 2013 05:59 PM
MoreCowbell
Oct 27, 2011 03:34 PM
SIRIUS VTEC
19
Aug 22, 2010 03:38 PM
Ress887
Mar 12, 2005 04:01 PM
heh
