Knock Sensor or TPS? What's causing this?
Old Jan 21, 2018 | 08:41 PM
ChrisF23's Avatar
Icon5 Knock Sensor or TPS? What's causing this?
Guys, i have a 1999 Accord, 2.3L, auto-transmission
Ok so, when i turn the car i don't have any CEL, but after some minutes driving, it turns on... The weird part is this:
If I start it, let it warm and floor it, it goes up to redline and everything seems fine... BUT after that, the CEL turns on... when this happens the car won't go over 4500 rpm... Even at highway speeds... if i need to pass another car, it will do the down shift, but stay at 4500 RPM until I take my foot out of the accelerator for a couple of seconds.
I don't have an OBD-I Scanner, but i did the wire method. and i got code 23. and code 7 which means KS and TPS...
I'm on a tied budget this days, and i want to know which sensor is more likely to be causing this for replacing it first... Thank you so much
Old Jan 21, 2018 | 10:03 PM
holmesnmanny's Avatar
Default Re: Knock Sensor or TPS? What's causing this?
it might just be that the ecu is bad
FOMULA91
Aug 25, 2013 04:17 PM
R_Machine
Sep 10, 2005 11:59 PM
GSRWSU
Aug 21, 2005 10:27 AM
stephenB!
Mar 12, 2004 06:33 AM
fastludeh22
Mar 21, 2003 04:53 AM
