No Reverse
Old Jan 20, 2018 | 01:34 PM
papp-fox's Avatar
Default No Reverse
Have a 97 Accord SE, Started the other day with no reverse when my son left school. Now we still only have drive. When you shift from park it makes a clunking sound and the motor/trans lean backward in the engine bay. Also the motor will not rev above 1500 rpms in any gear. I have checked the cable/linkage and it is move through all of the gears at the trans and fluid level is good. I am worried that maybe the converter is locked up or broken main shaft but hoping for an easy fix. Any ideas on what to look at next?
Old Jan 20, 2018 | 02:57 PM
holmesnmanny's Avatar
Default Re: No Reverse
have you scanned for codes
Old Jan 20, 2018 | 03:41 PM
papp-fox's Avatar
No codes pertaining to the transmission. I have some emission codes P0441,505,170,171.
Old Jan 22, 2018 | 08:04 AM
papp-fox's Avatar
Still no luck finding an answer. I Have tested the Lockup solenoid and it reads 14.2 ohms. I am understanding that 12-25 is normal. The car seems as though it is stuck between park and reverse and not letting the trans free. Any additional things to look at before pulling the trans?
Shahab_Zia
Dec 9, 2018 10:41 PM
02NCAccord
Sep 10, 2013 04:24 PM
Gizler00
Mar 25, 2009 07:41 AM
NMef9
Dec 26, 2006 07:00 AM
Rasago
May 3, 2006 01:00 PM
