No Reverse
No Reverse
Have a 97 Accord SE, Started the other day with no reverse when my son left school. Now we still only have drive. When you shift from park it makes a clunking sound and the motor/trans lean backward in the engine bay. Also the motor will not rev above 1500 rpms in any gear. I have checked the cable/linkage and it is move through all of the gears at the trans and fluid level is good. I am worried that maybe the converter is locked up or broken main shaft but hoping for an easy fix. Any ideas on what to look at next?
Re: No Reverse
Still no luck finding an answer. I Have tested the Lockup solenoid and it reads 14.2 ohms. I am understanding that 12-25 is normal. The car seems as though it is stuck between park and reverse and not letting the trans free. Any additional things to look at before pulling the trans?
