1996 Honda Del Sol Door Won't shut
Old Jan 16, 2018 | 03:34 PM
fast6fan's Avatar
Default 1996 Honda Del Sol Door Won't shut
The door won't shut and when I pull on the handle nothing happens in the door. What can I do to get it closed and what could my problem be? What do I do to know what my problem is? Thanks
Old Jan 17, 2018 | 08:29 AM
rober0193's Avatar
Default Re: 1996 Honda Del Sol Door Won't shut
This was actually happening to me in my del sol as well. Make sure the latch part on the body of the car is intact and facing in a direction that will insert into the door properly.
Old Jan 17, 2018 | 11:36 AM
mk378's Avatar
If the latch has been thrown to the closed position while the door is open, you will need to use a screwdriver or something to pull on the latch piece while you move the door handle so it unlatches. Then you should be able to close the door.
doklo
Apr 6, 2021 03:54 PM
tuvtec
Oct 8, 2014 12:01 AM
toben
Feb 24, 2007 08:05 PM
DelSolMarine
Aug 31, 2006 02:15 PM
