Replacing LMAs B16a
Old Jan 15, 2018 | 12:21 PM
egsleepercivic's Avatar
Default Replacing LMAs B16a
JDM B16a
Do the rockers have to come out to replace the LMAs.
Also are these the correct spring type LMAs for a B16a
14820-PCB-305
https://honda-tech.com/forums/acura-.../lmas-3244333/
Last question, where is the best price on OEM spring type LMAs ?
Thanks
Replacing valve seals now that why I am asking....
Old Jan 16, 2018 | 08:21 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Replacing LMAs B16a
I do not know how to access the LMA without the rocker assembly being removed from the head.
Looking at skunk2's website, the B-series LMA springs are the same for both B18 (GSR, Type R) and B16 (99-00 Si [CDM SiR]):
https://skunk2.com/312-05-0200.html
Old Jan 17, 2018 | 04:42 AM
Thanks for the info.
I have the cams out, I replaced the valve stem seals, and it looked like you might be able to get the LMAs out, but it also looked liked they might hit the rockers.
Thanks again. also I was going to try to stay OEM on the LMAs, but I see they have the same ones listed for all.
Old Jan 17, 2018 | 05:19 PM
98civdx's Avatar
Master Detailer
Unfortunately, the rockers need to be removed.
Old Jan 17, 2018 | 09:54 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
How are the cams out without removing the rocker assembly?
Old Jan 18, 2018 | 05:07 AM
Maybe I am not using the right term, Rocker Arms ? the things that ride the valves...the cams are out. you can swing the rocker arms out of the way and access the springs to replace the valve seals
Old Jan 18, 2018 | 03:46 PM
This is why I asked TomCat
Old Jan 18, 2018 | 06:49 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
FSM shows pulling the rocker arms out then goes onto explain rocker arm assembly. After rocker arm is assembled and tested, it says to remove the LMA. What isn't clear is if this is assebled on the rocker arm shafts or outside of the head.
I now see the B16 setup is significantly different than the SOHC vtec setups.
Personally I think it's better to have everything out when doing the LMA's but that is me. Also FSM does say rubber band the arm assembly together in sets, that to me sounds like it's removed from the head before moving onto the LMA's
slowls
Mar 25, 2017 08:56 PM
TheWhitten
Engine Machining & Assembly
Nov 20, 2015 09:03 AM
Mario.
Dec 6, 2004 04:06 PM
98jdm_coupe
Mar 31, 2004 04:28 PM
ltho1998
Aug 7, 2003 06:17 PM
