H2B H22A w/F22 crank main seal oil leak
Old Jan 14, 2018 | 09:12 PM
gmcuajo1's Avatar
Default H2B H22A w/F22 crank main seal oil leak
Hello all!
Anyone here using a F22 crank (95mm) on an H22 block?
As above says, I have an JDM H22A block with an F22 95mm stroke crankshaft and con rods. The problem I am having is that (apparently) the main seal is leaking a lot of oil. When I say a lot, is just way too much.
I haven't confirm is the main seal (didn't had time to), but don't think there is other place that can leak on that side.
I pulled the out because​​ of this and decided to do the H2B. I put a new oil seal, but started the motor just to see that it is leaking. Engine was running for just a few minutes, and the leak was too much.
Does anyone have similar setup?
To tell a bit more, I bought the car already with the H22 and the F22 95mm crank, balance shaft eliminated with Ktuned kit, and manual tensioner.
​​​​​On the pictures it havd the flywheel spacer.
Old Jan 15, 2018 | 11:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: H2B H22A w/F22 crank main seal oil leak
Can you take a picture without the flywheel spacer/adapter on the crankshaft end please ???
Old Jan 17, 2018 | 05:34 PM
gmcuajo1's Avatar
Unfortunately I am not where the car is right now, and it is in tbe car with the transmission. On the pictures you can see the edge of the spacer. What I think can be happening is that I pushed the seal too far in.
Charlie Moua
Feb 4, 2012 08:49 AM
DC4_MADMAN
Aug 9, 2006 10:49 PM
se93
Jan 8, 2003 07:13 PM
ares650
Oct 14, 2002 08:13 AM
