H2B H22A w/F22 crank main seal oil leak
4 Attachment(s)
Hello all!
Anyone here using a F22 crank (95mm) on an H22 block? As above says, I have an JDM H22A block with an F22 95mm stroke crankshaft and con rods. The problem I am having is that (apparently) the main seal is leaking a lot of oil. When I say a lot, is just way too much. I haven't confirm is the main seal (didn't had time to), but don't think there is other place that can leak on that side. I pulled the out because of this and decided to do the H2B. I put a new oil seal, but started the motor just to see that it is leaking. Engine was running for just a few minutes, and the leak was too much. Does anyone have similar setup? To tell a bit more, I bought the car already with the H22 and the F22 95mm crank, balance shaft eliminated with Ktuned kit, and manual tensioner. On the pictures it havd the flywheel spacer. |
Re: H2B H22A w/F22 crank main seal oil leak
Can you take a picture without the flywheel spacer/adapter on the crankshaft end please ???
1 Attachment(s)
Originally Posted by JRCivic1
(Post 51534269)
Unfortunately I am not where the car is right now, and it is in tbe car with the transmission. On the pictures you can see the edge of the spacer. What I think can be happening is that I pushed the seal too far in. |
