Dead GSR, No Start, Code 0
Old Jan 14, 2018 | 12:37 PM
GreatWave's Avatar
10 Year Member
Default Dead GSR, No Start, Code 0
alright dudes, my GSR died in the rain the other day, and if you haven't seen my build thread, I'll get you up to speed. Car is a 98 LS with a 95 GSR swapped in. Swap went well back in April, no issues until now. OBD1 P72, Rywire VTEC sub-harness, Skunk2 intake mani and TB, header and exhaust. Just your basic bolt-on engine. A few weeks ago my starter decided to melt all of my grounds to chassis (valve cover, battery, transmission), as well as the power cables to the fuse box and starter. All of that was replaced the same night, and I've been driving since with no issues. Driving to lunch the other day it died in the rain. Cranks, will occasionally fire and run for 5-10 seconds, and dies. So far i have cleaned/tapped/sanded all grounds, tested multiple main relays, two computers. The main relay likes to click rapidly with the key in position ll and the fuel pump runs constantly when the key is on, verified by pulling my pressure gauge off the rail and watching fuel go everywhere. The ECU still won't flash a code, just a solid CEL. I'm not sure if this has anything to do with the starter melting my grounds a couple weeks ago, but I replaced batt-chassis, trans-chassis, VC-chassis, and batt-fuse box/starter. The SRS light is on steady, and the brake light comes on when cranking the engine. Hoping for the best, but prepared for the worst.
Old Jan 14, 2018 | 05:35 PM
tamboo's Avatar
10 Year Member
Default Re: Dead GSR, No Start, Code 0
bad ecu?
https://honda-tech.com/forums/honda-...e-0-a-2999474/
Old Jan 14, 2018 | 06:09 PM
GreatWave's Avatar
10 Year Member
I considered that, but I swapped in another known good ecu with the same results. Resetting the ecu won't even clear the cel.
Old Jan 15, 2018 | 05:08 PM
tamboo's Avatar
10 Year Member
i cant get rid of a bad code 20 but runs fine so tea & sympathy.
if not done already removing and cleaning relevant grounds would be a plan.
as good old fcm says do not simply eyeball them. 8)
Old Jan 15, 2018 | 06:01 PM
GreatWave's Avatar
10 Year Member
Been there, done that. This is definitely a frustrating issue. New harness is in the mail, going to make sure to eliminate that as an issue after the starter melted all the grounds. Everything has been cleaned and sanded and I replaced all the grounds with new cables
Old Jan 21, 2018 | 01:42 PM
GreatWave's Avatar
10 Year Member
Replaced engine harness, repaired fuel pump harness under the rear seat, still won't start. Tested more ECUs/relays, and even an ignition switch, to no avail. Distributor, injectors, ecu are all receiving 12v. I can't figure this thing out. Any more suggestions?
Old Jan 21, 2018 | 02:40 PM
tony_2018's Avatar
Fish Twig
swap fusebox?
Old Jan 21, 2018 | 03:13 PM
GreatWave's Avatar
10 Year Member
Not yet, I have to borrow one from a friend. I'm also taking my ecu to work tomorrow and testing it in one of our ITRs.
Old Jan 22, 2018 | 01:30 PM
GreatWave's Avatar
10 Year Member
Looks like my ECU is dead. I installed it in our DB8 type r at work, and it's doing the same thing the gsr is doing. Looks like I got my answer.
Old Jan 29, 2018 | 05:27 AM
GreatWave's Avatar
10 Year Member
Replaced the ecu with a chipped P28 from phearable and the car runs like a top now. Apparently the shorted fuel pump connector friend my ECU.
Old Jan 30, 2018 | 12:25 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
explain.
because my ecu just fried as well. im getting my replacement tomorrow
Old Jan 30, 2018 | 02:29 PM
GreatWave's Avatar
10 Year Member
I had a horribly corroded fuel pump connector under the rear seat and it shorted something in the ecu. Once I repaired that the new ecu worked fine upon installation. I burned up two old ecus and went through my entire harness looking for shorts/grounds.
teg420
Honda CR-V & Element
Nov 22, 2012 02:22 AM
VoodooXIII
Jan 5, 2010 12:58 PM
92IntegraPOS
Dec 30, 2008 08:36 AM
midnitesol
May 11, 2007 06:48 PM
Integra_Boi
Jul 30, 2003 12:31 PM
