Classic Hondas All Pre-1988 Hondas.
89 Honda Accord LXi Engine Code 6 not fixed by ETC sensor, sending unit or switch
Old Jan 11, 2018 | 11:24 AM
Thomas Lilley's Avatar
Default 89 Honda Accord LXi Engine Code 6 not fixed by ETC sensor, sending unit or switch
Hi all, first time posting on here. Here goes nothin. Bought an 89 Accord sedan LXi. Engine code 6 led blinks on ECU. CEL used to be on all time with hard start. Changed out ETC after finding another post about the light blinks and diagnosing, etc. Now starts right up, gets up to temp and idles fine without CEL coming on. Drive for 1.5 mins and boom, on comes CEL with same 6 blinks. Replaced the temp sending unit next, temp reading same. no change to CEL status (off at start, comes on when driving). Replaced the radiator cooling fan switch and it came on great the first startup, now fan does not come on. no blown fuses. IDK what to do next. It doesnt overheat, only problem now is that the battery light comes on. Help would be appreciated. TIA!
TJ
Old Jan 11, 2018 | 12:52 PM
holmesnmanny's Avatar
Default Re: 89 Honda Accord LXi Engine Code 6 not fixed by ETC sensor, sending unit or switch
https://www.hondapartscheap.com/auto...er=37750ph2014
what parts did you replace ?
it's possible the ecu is bad if the wiring is known to be good
Old Jan 11, 2018 | 02:58 PM
The engine temperature control sensor, the temperature sending unit and the cooling fan switch for the radiator. Not 100% on wiring for the ETC sensor or cooling fan. I assume the ETC is good because light used to come on at start and stay on but now it doesnt come on until the engine is up to temperatire and driven for about a minute.
Enrique E
Dec 29, 2017 01:01 PM
street_ride14
Mar 14, 2015 10:48 AM
Blaze4g63
Feb 17, 2015 09:17 AM
chriscar00
Aug 25, 2013 05:46 AM
