2007 Accord 4 cyl auto Code P2185 ect 2
My daughter has a 2007 Accord 4 cyl automatic was in major front end collision. The harness broke at bottom of radiator for the temp fan sensor we connected wires direct ,worked great for years. Now sensor was replaced and check engine light won't turn off. Where can I get a harness? Any suggestions on the fix? Thank you
Re: 2007 Accord 4 cyl auto Code P2185 ect 2
I would start by seeing what the Check Engine Light is on for, use a OBDII scan tool or stop by an auto parts store that will scan codes for you. I am assuming you only know the light is on and are suspecting the problem to be related as you didn't say what code was causing your CEL. If the code is related to the fan temp switch chances are you are right and have a short to power or ground or possibly on open in the wiring harness somewhere. You could fix it with some testing and troubleshooting.
If it is certain the code is for the fan temp switch and you want to order a harness, there are a few different sites online to order OEM Genuine Honda Parts, I'm not sure which harness specifically you need or what trim level the car is (EX,LX,EX-L, DX) or if it is a Coupe or Sedan but here is a link to "Honda Parts Wholesale Direct". *The link is to a EX Sedan wire harness page in the catalog, it was my guess lol so don't accidentally order direct from the page unless you have an EX Sedan obviously.
https://www.hondapartswholesaledirec...e-harness-scat
Thomas Lilley
Classic Hondas
01-11-2018 02:58 PM
