Timing belt too loose on front side and tight on rear
i did my timing belt/water pump on my 01 civic and put a helicoil on the stripped tensioner bolt hole. I installed the spring and put a pin to hold the 2 holes on the tensioner together then tightened the bolt to 40lbs and removed the pin. But it seems like the belt from the front (exhaust side ) is looser than the right (intake side) feels pretty loose but the rear is tucked tight. I'm scared that it might jump a tooth. Any of you know if that's normal?? the belt on the cam gear feels snug but the part of belt going counter clock wise to the crank shaft feels loose .
The tightest part should be between the water pump pulley and the cam gear. It is normal that the long belt gap between the cam gear and the crank gear (at the front as you have described it) to feel more loose than the short run between the water pump and the cam gear. Now, food for thought: Did you, as outlined in the factory service manual, rotate the crank pulley until the camshaft lines up three teeth from horizontal TDC and then torque the tensioner bolt to 40 ft/lbs. ??? If not, properly tension the belt per the FSM and then test the slack in the front side of the belt.
Ok so now I feel a bit better a buddy of mine told me to keep cranking the car on until I felt the difference I guess when the pistons land on a certain location I feel more tension on the belt then when it lands otherwise.
OP. Unless I'm mistaken, he's trying to tension the timing belt while cranking the engine with the starter. This has potential to slip teeth on the belt and set his pistons and valves up on a blind date.
i think he's referring to checking the feel AFTER it has been tensioned...ie bolt tightened
91 b20 integra
Sep 22, 2014 08:44 AM
realis9
Aug 26, 2007 12:52 AM
