98 Civic EX AT fuel economy
Old Jan 6, 2018 | 01:28 AM
Smithcraft's Avatar
Default 98 Civic EX AT fuel economy
Hello!
I'm getting an average of around 27 MPG. I'm thinking it should be better, as it was getting low 30s when I bought it. I drive fairly conservatively 'cuz the tires (Les Schwab cheap tires) that are still on it aren't that great.
So back when I did the tune up (cap/rotor, plugs, valve cover gasket) in July, I think I might have forgotten to connect something or maybe a brittle hose has cracked.
I'm wondering if there is something I might want to look for, or if there are any suggestions.
Thanks!
SC
Old Jan 6, 2018 | 02:27 AM
Chance EG's Avatar
Default Re: 98 Civic EX AT fuel economy
Make sure timing on distributor is where it should be.
Check for vacuum leaks if you think you split a hose. Look over your work and make sure you're not missing anything.
Check tire pressures and make sure each is inflated fully.
Old Jan 7, 2018 | 01:26 PM
adamhunsicker's Avatar
10% decrease in fuel efficiency, started (I'm assuming) about the time the weather got cold. My money is on under-inflated tires.
Old Jan 7, 2018 | 08:36 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
As well as colder air means more fuel in general, longer in open loop and even in closed loop more fuel for the denser air.
Fuel economy always goes down in the winter.
Old Jan 8, 2018 | 02:06 AM
Smithcraft's Avatar
Actually, it started in July.
SC
Old Jan 8, 2018 | 02:08 AM
Smithcraft's Avatar
The tires are slightly under inflated for winter weather traction, but that's because they are the worst tires ever (Thanks previous owner!), and I'd spend more time spinning the tires than moving.
SC
Old Jan 8, 2018 | 05:23 AM
civic402lx's Avatar
Maybe start looking for better tires?
a side from the regular tune up and everything perform normal, there is not much else you can do.
i would join the ecomodder site and see if they can offer more insight.
Old Jan 9, 2018 | 05:26 AM
egsleepercivic's Avatar
did you use OEM cap and rotor, NGK plugs ?
Old Jan 9, 2018 | 05:29 AM
CandyRedRC46's Avatar
I was going to say this. Also to add to this, Did you properly gap the plugs???
Old Jan 13, 2018 | 12:18 AM
Smithcraft's Avatar
I used a Standard Motors cap and rotor, NGK V Power plugs, and NGK plug wires.
I gaped the plugs to 1.1 mm.
SC
IntegraTypeR
Feb 20, 2007 12:43 PM
kaj
Jan 21, 2006 12:07 PM
Team 4R
Dec 14, 2004 08:56 PM
downpipe
Aug 23, 2002 03:08 PM
