IACV problem
Old Dec 24, 2017 | 08:27 AM
Shojin's Avatar
Default IACV problem
Hi everybody, i have a problem with my IACV: when i plug it the rmp go down very slowly when i left the throttle and some times the car idle at 1500rmp, when i don't plug it the car runs fine. I have cleaned it and the problem isn't solved. Now my question is: if delete it is going to change something or it is just a bypass for the problem? How fuel economy will be?
Thanks.
Old Dec 24, 2017 | 02:55 PM
Megalodong's Avatar
Default Re: IACV problem
IACV is only in use during idle. DId you clean the IACV gasket/screen when you removed it?
Pull a IACV from a salvage yard and see if solves the issue. Also, clean the throttle body and do a smoke test for vacuum leaks.
vtec5genhatch
Mar 17, 2013 08:25 AM
turbo_ls_69
Aug 5, 2010 04:40 PM
R. Mack
Jun 1, 2005 07:55 PM
rice a roni
12
May 24, 2005 12:31 PM
Takashi1978
Nov 27, 2004 06:42 AM
