My 93 EG and ME
Whats up Honda enthusiast and everyone else!
I am not too sure where to start with this. I think I am in the right area. I am opening/starting a thread to keep track of my progress and hopefully (stretching that word) hopefully get some help and knowledge from some of the most experienced Honda Tech members and Honda mechanics. There are a few other reason I am starting this thread but that is boring. SO I will give a very short run down of what I am working with. I have a 1993 milano red Honda Civic EG hatchback. It has an H22a motor with an Integra Type R transmission. It has minor bolt ons. No internals. I will post photos asap to give a better idea.
I have a plethora of questions. I figure instead of opening threads all over the place for the information I can not find right out the gate that I would have 1 thread and ask them all in the 1 thread. I don't expect to have anyone reply or come up with perfect answers to my questions. This is also a helpful area for me to log my findings and help others with information that they can not find either. For an example, I might ask a question and hear nothing. I will continue to research and research until I do find an answer. Then I will post my finders here. It is a good place for me to keep things straight and in order on my EG. Along with having a chance to get a response to slow my continuing search for information/knowledge. Last but not least. If my questions make no sense, sound ignorant or just down right STUPID....just hang with me. Thanks.
Lets get to it...
I am trying to absorb as much information I can on tuning recently with Hondata on a P28 ECU. When I want to datalog with Hondata. What is the process I have to go through to do that? I know that is a very open ended question. But I dont understand once I have hooked my ECU to my car and I have it also hooked up to my laptop and SManager open I then hit the "record button"? and drive around town for a few days? To and from work, daily driving kinda stuff?
Lets get to it...
Your specific question right now of Hondata and it's processes might fare better in the engine management section.
I would slap a post in there but without the first paragraph, just the short and sweet, P28 ECU, Hondata and laptop. Do tell them what version Hondata you have, I'm assuming it's the S300.
Thanks Tom, I appreciate the reply. It is an S300. I have figured out that is basically what I have to do. That the more times I datalog/record and daily drive the better. I can get a more over all reading that way. My ultimate goal is to be able to street tune my EG myself and get it as close as I possibly can to the correct tune for my type of daily driving. I have heard many horror stories of guys taking their cars to the dyno and having a tuner blow their motor right in front of them. The shop close to me, one of the tuners is really good, then I hear that one of them really messed up a few cars. The owners of those cars told me the same. I rather have it as perfect as I can without taking it in. In fact I would like to rent or pay for the pulls and do it myself in a perfect world. The shop I live close to will rent it out. Its about $200 less for me to do it myself. Im not drag stripping my EG or even tracking it. All im looking for is a quick smooth daily driver that I can rack the miles up on. I feel like I myself should be able to tune for that. One plus is I am already running a P28 ECU. I can always switch it back.
Right now, I am trying to find information on using a Wideband 02 sensor compared to using a Narrowband 02 sensor. The benefits to each if any and if using a Wideband is completely necessary or if narrow will do the job for what I am looking to do. Before I dive in I have to have all my ducks in a row.
Thanks to anyone stopping by and taking time to read this. Happy Holidays!
To datalog, have your laptop plugged in and hit the record button. When you view your graphs you will see the realtime datalogging. It records all sensors, but you can customize which ones you want to overlay on different graphs in the options.
A wideband is an essential tool for tuning. However, it is generally not needed after tuning is complete. Lots of people keep them installed with a gauge, especially on forced induction, to keep tabs on their AFR for signs of any problems.
A narrowband is only good for running closed loop, during normal driving to keep the AFR near 14.7:1 for fuel economy.
For a daily driver, I would agree with keeping the narrow band for closed loop. You can choose to run only in open loop (option in Smanager), where the narrow band is not used, but this should only be done when tuning. Add a second bung for the wideband, hook it up to your ecu for datalogging purposes and you are ready to street tune.
You can control the parameters for closed loop, or under which the ecu uses feedback from the narrowband to adjust fuel trim. Generally it only comes into play when below a certain amount of throttle and rpm, and when the engine is up to temperature.
Damn, lookin good!
The best procedure for tuning a new setup is as follows.
1.) Open a new base map in Smanager from the stock engine that most closely matches yours
2.) Switch it to Open Loop
3.) Adjust fuel injectors and trim to compensate for different fuels or injectors you have. This includes injector size and dead times. Also select the proper MAP sensor if not OEM.
4.) If forced induction, apply a base timing retard per psi of boost. This amount will vary based on fuel, compression, etc.
5.) Upload base map to ecu, the car should start. Wait for it to reach full temp to make any adjustments to fuel
6.) Adjust idle AFR, then datalog normal driving to adjust fuel maps
7.) Datalog and tune WOT pulls and watch AFR gauge to ensure your aren't leaning out
8.) Once AFR is close to where you want it for driving, closed loop can be enabled.
9.) Check spark plugs for any sign of detonation
10.) There is some other voodoo magic for adjusting timing, but I have never messed with it for a street tune. Just ran conservative timing. If you want this dialed in, go to a tuner with a dyno.
Damn, lookin good!
Info on the cheap for this would likely be appreciated by many.
Your best sources are forums such as this, the Hondata forum which has been a great resource for me, and independent internet research. A lot of tuning is trial and error and won’t make sense until you upload a tune and see the results. My biggest recommendation is to make sure you save every iteration of every calibration you create, and only change one thing at a time. The smallest change can have a major impact on your tune and you want to be able to “undo”.
The overall majority learn by trial and error, but obviously that's a scary concept when dealing with engines costing thousands of dollars lol. YouTube has some scattered videos on Hondata and Neptune tuning procedures which can at least help you learn the overall plane of things.
Personally, I've never tried to "tune" anything beyond uploading a base map like 2x0 listed above, and until I have an engine that I wouldn't mind risking it with, I won't try tuning a car myself.
Tuning a car to make it driveable and make some reliable power is easy, if you have the right tools and use them properly. Wideband AFR gauge, reading spark plugs, and datalogging can get you to about 95% of what a dyno tuner can do. It’s very empowering to do this yourself.
Are there risks? Of course. Just like there are risks building your own engine, or putting together a turbo system. With any of these, all you can do is research and do your best, hoping it doesn’t fail.
We learn more from our failures than our successes
Thank you once again 2X0. This is one of the reasons if not the main reason I made this thread. I attached a few questions as you can see. But they are questions for me as well. I like to keep notes in my phone notepad and on my laptop. I consider this a "notepad" while being able to have the opportunity of others to chime in and possibly speed up the (never ending) process of me finding out the important info I need to continue to make the best out of my Honda. Those are questions that pop in my mind when I read your check list. It has been a tremendous help!
Q: Where is this option in Smanager? I looked through it but must have missed it. Or is it not an option until ECU is joined with car and also laptop? How well does a download from Hondata forums work. Ive seen a few guys throw up maps for download. Is it pretty risky? As in downloading then uploading then starting you car up.
Q: This is ONLY AFTER I have the wideband 02 sensor/Gauge installed correct?
Q: So, I know I have factory injectors so I'll be choosing the 345CC, But what or where would I find what trim is safe or correct? Or how do i find out a proper trim? All of these options are OEM for me. Dead times I'm going to have to read up more on.
RIP tires. I can barely hook it as is. I cant imagine. HA
Q: I guess again, Where should I look for a quality base map. I did see an interesting option on HAmotorsports website that you can easily choose your basemap options (MAP sensor, Fuel Injectors, Launch Control, Shift Light, Rev Lim, O2) then order that basemap. Then download the file they send you via email (I guess) from them for $29.99. Basically you fill the options in and they will make the basemap and send you the finished product. Your thoughts? Q: On the fuel adjustments after your car has warmed up to operating temperature, what is a "drastic" adjustment? SO I know not to go too high. If the car just wont turn over or "putters" I should slowly increase fuel?
Q: Again, when adjusting the AFR whats extreme? Low and High.
Q: At this point my car should be able to make it around the block I would think. After lets say I do some normal driving what do you mean by "then datalog normal driving to adjust fuel maps." I know I will hit record in Smanager then go do my normal driving but the "to adjust fuel maps" is a little confusing to me. Could you go into anymore detail on that?
Q: When I and dataloging wide open throttle pulls and watching my AFR gauge, What is too lean and what isnt. Anything higher than 14.7 on a WOT pull? 14.7 on regular normal everyday driving? I need to read much more on this subject for sure.
Q: Im lost right about here. Haha. If i set the AFR with the wideband then enable my OEM narrowband back into commission how does that not reset my wideband adjustments?
Q: What causes this? Running lean? Is there any warning signs to this? So that I can weed it out before I start to adjust something else thinking its something else. If that makes sense.
The weather here is **** right now. Its single digits and snow on the ground. I'm basically garage livin and trying to absorb everything before spring so I can hit the ground running. I couldn't even drive the hatch let alone WOT pulls. haha I totally understand the part of not knowing until you actually go out and get your feet wet and start tuning. I'm extremely happy that Ive had some sound advice and activity here. Its awesome...
The answer to all of your Smanager related questions can be found below. I would recommend going thru each and every option in this help guide so you understand what everything does.
https://www.hondata.com/s300-help
So to start your new base calibration, you go to File > New and pick from the many basemaps available.
I would not bother using peoples maps they have posted online, you don’t know what they might have changed. You’re better off using a known starting point, being a tune from a stock engine and go from there.
If you are using OEM injectors, you shouldn’t need to change anything in the fuel trim or injectors tab. Fuel trim is more for things like different fuels, such as e85 which requires about 30% increase across the board, or adjusting for different fuel pressures.
At idle and anytime in vacuum, you want to aim for 14.7:1 AFR. I usually richen it up to about 13:1 right at 0 vacuum, and in boost 11.5:1.
I’ll have to get to the rest of ur questions tomorrow.
From what I have been reading. My motor is taking in a hell of a lot more air now with the upgrades then before. I was having a little bit of a rough idle issue. I ran through the vac lines again to see if there was anything open. I found bigger problems with the old vac lines then i wanted and i fixed those. But winter came and with fresh vac lines attached i cant take her around and see if that had fixed the issue. I went down a list to try to narrow down the issue. I'm pretty confident it was a vac leak. I'm a little worried to put the new Hondata equipped ecu on too soon. I want to make sure shes running well or as close as possible before i put the new ecu on. Or could my issue be the new upgrades on the motor causing it also. Anyone have any thoughts on that? When i hook the new ecu up, will Hondata tell me issues that need to be fixed (codes) before i dig in or will it let me tune my car if there is still a vac issue? I have two ECUs. One has the Hondata obviously, the other doesnt. Right now im using the one without hondata. Should I just hook the new ecu up and go through the motions as in let it warm up to operating temps, daily drive to let that ecu learn/teach and see how it reacts? Then go from there and tune?
If you start with a basemap from the ecu that does not have Hondata, then the car should run exactly the same with either ecu. Except with the Hondata, you can hook up your laptop, record a datalogs and see exactly what your engine is doing. Watching your MAP reading should tell you if it's actually a vacuum leak. Maybe you actually just need to tweak timing or fuel a bit to smooth out your idle.
Do i need any special gear to do the timing?
When i plug the new ECU in and pair my laptop up to it. I turn the key and start it, then hit the record datalog button. How long would i need to record to be able to see what if anything is wrong. Will it tell me some things in idle and some other things when driving. Or is there a location inside SManager that i can go to and see exactly what might need some attention or is faulty?
When calibrating my wideband after install i will check the reading on the wideband gauge at idle once my car has reached operating temp and check my AFR on SManager too. Is that all that I have to do in order to make sure its calibrated?
Most healthy Honda engines I've known will pull at least 18 inches of vacuum at warm idle, but plenty have done 20 or more. It should hold steady and not fluctuate, as should idle RPM.
I wouldn't tweak fuel until you have a wideband setup. Then you'll know how much to tweak it. I usually set my fuel table increments to 1% per click, but knowing that 1% increase or decrease usually translates to a 0.1 AFR change. So if you are off from your target by say 0.5 AFR, you may just go ahead and adjust that fuel column by 5%.
I would datalog whenever it is that you perceive there is an issue, and long enough that you capture the issue occurring. It might only take 5 seconds of datalog to capture a rough idle. Or you might datalog an entire drive trying to capture a random occurring event. It is up to you.
You will want to graph the things that are important or that pertain to what issue you are having. A standard graph might include RPM, throttle position, MAP, wideband o2, fuel pulse, VSS, and anything else you deem necessary. These things give you a wealth of information about what is going on, but you have to research and come to thoroughly understand how each is interrelated in order to put that information to good use.
I wouldn't recommend messing with timing tables in Smanager until you are on a dyno. Make sure your mechanical timing is correct and adjust the distributor with a timing light before looking for a problem with the calibration. The stock timing map should work fine until dyno tuning unless you have some extreme cams or head work done.
Excellent, the more I get into the forums on hondata website and especially in the S300 help section you are making more and more sense. I plan on getting it to a dyno to do timing. Its stock cams and stock internals anyways. But i hope to have everything where i want it before i pay to dyno.
I will wait until i have the wideband set up correctly before i mess with fuel. Could i technically hook the Hondata ECU up and load a basemap/all the minor stuff and start the car and datalog the idle to find out what the issue is? I then fix it and slap the old ecu on until i can get the wideband. I know it sounds kinda dumb to go back an forth between ECUs but just curious. Thanks 2.
Best way to diagnose a vacuum leak tho will always be to blow some smoke around the engine bay.
