1993 accord will not run
Old Dec 22, 2017 | 03:17 AM
rcruz's Avatar
Default 1993 accord will not run
Hello, New to this site. Ive been researching trying to fix my no start issue.
I bought a 1993 Accord and a wrecking yard motor was installed but hasnt been started since install. It will crank fine but will not start. This is what I have done to it.
Replaced timing components, I double and triple checked and timing is correct. new distributor, new plugs and wires,new main relay/ I do have spark, I checked pressure on fuel rail and has good pressure, Check for power on each injector lead and thats good. I tested pulse with a noid light and this is where I am unsure of. It get pulse after about 7-10 turn over when cranking. Im I suppose to get pulse soon as I crank? Not sure if my ECU is out? Please and help greatly appreciated.
Thank you
Old Dec 22, 2017 | 03:30 AM
rcruz's Avatar
Default Re: 1993 accord will not run
I just tried cranking this morning to see if noid light would come on and it came on rite away bright. I shut key off and tried again the it went back to faint but after about 5 time motor turned over.
Old Dec 22, 2017 | 07:02 AM
holmesnmanny's Avatar
check compression, make sure the engine is healthy
Old Dec 22, 2017 | 04:03 PM
rcruz's Avatar
I did check compression and all pretty even and good.I shot starting fluid into the throttle body and didn't attempt to fire which lead to timing. I double check timing and all is correct. I do get spark but not want to start
Old Dec 24, 2017 | 09:35 AM
if comp is good then the mech timing is good, maybe try another ecu
Old Dec 26, 2017 | 07:44 PM
rcruz's Avatar
Got another ecu and fired rite up. Thanks for replies
roberfro
Feb 3, 2013 06:50 PM
chickendance
Mar 12, 2012 03:48 PM
hard_boiled_EG
Nov 21, 2009 07:24 AM
upstatee
Oct 13, 2008 07:23 AM
