1993 accord will not run
Hello, New to this site. Ive been researching trying to fix my no start issue.
I bought a 1993 Accord and a wrecking yard motor was installed but hasnt been started since install. It will crank fine but will not start. This is what I have done to it.
Replaced timing components, I double and triple checked and timing is correct. new distributor, new plugs and wires,new main relay/ I do have spark, I checked pressure on fuel rail and has good pressure, Check for power on each injector lead and thats good. I tested pulse with a noid light and this is where I am unsure of. It get pulse after about 7-10 turn over when cranking. Im I suppose to get pulse soon as I crank? Not sure if my ECU is out? Please and help greatly appreciated.
Thank you
Thank you
Re: 1993 accord will not run
I just tried cranking this morning to see if noid light would come on and it came on rite away bright. I shut key off and tried again the it went back to faint but after about 5 time motor turned over.
I did check compression and all pretty even and good.I shot starting fluid into the throttle body and didn't attempt to fire which lead to timing. I double check timing and all is correct. I do get spark but not want to start
chickendance
03-12-2012 03:48 PM
