1991 Acura Integra Ls problems with ecu fuse.
Old Dec 19, 2017 | 04:10 AM
Xxslushyy's Avatar
Default 1991 Acura Integra Ls problems with ecu fuse.
hey guys!
So I’ve read and read and read.
Problem started with obvious water. Cleaned up had car running but alt. Was charging at 16a.
my neighbor said let’s unhook negative cable see if she shuts off.. well she didn’t.
he pressed the throttle cable a smidge and she chugs out and he very quickly put neg cable back.
she still shut off. Now WILL NOT START and blows ecu fuse every key turn. Forums said check
the ecu by unplugging and turning key if it still blows it’s from relay to plug. Well ECU fuse does not blow
if ecu is not hooked up.
Alternator has been replaced still same thing.
Is ecu bad? What would be my next step. I’ve looked over most wires not underdash but all under the car
from where she got wet.
Old Dec 19, 2017 | 12:02 PM
CandyRedRC46's Avatar
Default Re: 1991 Acura Integra Ls problems with ecu fuse.
Seriously, if I had a dollar for every time I heard some dumb *** say, "pull the battery terminal while the engine is running, to test the alternator", I would be eating a nice NY Strip and your ECU would still be fried....
Old Dec 19, 2017 | 02:11 PM
flipsek's Avatar
sounds like the ecu was the problem to begin with....try a new one let us know what the out come is!
Old Dec 20, 2017 | 04:44 AM
No the ecu was okay, until he disconnected the battery while the engine was running.
Old Dec 20, 2017 | 12:46 PM
Xxslushyy's Avatar
Any suggestions on the new ecu.. used one off eBay ? Or aftermarket or from Honda/Acura. I’ve changed motors never replaced a ecu from scratch.
Old Dec 25, 2017 | 07:07 AM
flipsek's Avatar
im sorry i stand corrected...i thought the car was rrunning like crap before all that
Old Dec 25, 2017 | 07:10 AM
flipsek's Avatar
easy plug and play....and 2 or 3 10mm bolts...its coved by the kick panel pass side right...as far as ecus you can run a stock one unless you want to upgrade
Old Dec 27, 2017 | 05:52 AM
I bought a refurbished and chipped ecu from these guys a few years back and it has been working great since. You should be able to get a chipped p28 for your application and an obd0 to obd1 harness to make it work.
https://www.ebay.com/sch/advancedign...1&_ipg=&_from=
https://www.hptautosport.com/product...xoCFb8QAvD_BwE
crxsi814
Jan 18, 2011 06:25 PM
hoursinexile
Nov 17, 2009 10:14 AM
anton_
11
Oct 15, 2009 08:09 AM
EJ1_203
Jun 16, 2006 07:38 AM
turbofreakjohn
Feb 15, 2006 05:00 PM
