Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
must turn steering wheel to crank start 09 civic
Old Dec 14, 2017 | 10:59 AM
CNCProgrammer's Avatar
Default must turn steering wheel to crank start 09 civic
I just put a new battery in my car and I am having trouble starting it. Had problems before replacing the battery as well. The car wont turn over unless I turn the steering wheel to the left what turning the key to crank it. Can anyone help me with this problem?
Old Dec 14, 2017 | 12:04 PM
holmesnmanny's Avatar
Default Re: must turn steering wheel to crank start 09 civic
likely the starter is bad, instead of turning the wheel hit thr starter with a hammer before starting it to test
Old Dec 15, 2017 | 10:15 AM
97emsedan's Avatar
It sounds like you might have a faulty ignition switch in your steering column. If the wheel needs to be cranked to the left on starting, it might mean that you have a broken wire in the ignition circuit that is making proper contact when the wheel turns left. The engine, once started, wouldn't need the circuit to be activated as the ignition doesn't engage after the engine is started.
Old Dec 15, 2017 | 03:22 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Does the key turn before you turn the wheel some?
Alice Jones
Honda CR-V & Element
18
Jan 26, 2018 03:30 PM
wwzjd
Feb 11, 2015 09:00 PM
Manoj Yadav
Jul 16, 2013 12:21 PM
bandit080000
17
Dec 24, 2008 05:55 PM
XplodeTeg
Oct 26, 2004 03:52 PM
