Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda Civic head light Low beam not working
Old Dec 12, 2017 | 06:58 PM
poms77's Avatar
Default Honda Civic head light Low beam not working
i have a honda civic 2002 model, anyone ever run into this...
when i turn my headlights, only the parking lights come on (no low beams). i flick the high beam switch and the high beams work fine. i switch them off and the low beams don't come on.
i have tested the bulbs and fuses they work just fine, tried replacing the headlight switch but still haven't solved the problem.
any idea what could cause the problem?
Old Dec 13, 2017 | 05:06 AM
NDNV's Avatar
Default Re: Honda Civic head light Low beam not working
Take your vehicle to a dealer for the headlight switch recall:
Report Date : May 4, 2007 at 10:32 PM
NHTSA Campaign ID number : 04V086000
Make / Models : Model/Build Years:
HONDA / CIVIC 2001-2002
HONDA / INSIGHT 2000-2002
Manufacturer : AMERICAN HONDA MOTOR CO.
NHTSA CAMPAIGN ID Number : 04V086000 Mfr's Report Date : FEB 24, 2004
Component: EXTERIOR LIGHTING:HEADLIGHTS
Potential Number Of Units Affected : 440000
Summary:
ON CERTAIN PASSENGER VEHICLES, THE LOW-BEAM TERMINAL ON THE HEAD LIGHT WIRE HARNESS CAN OVERHEAT AND COULD CAUSE THE LOW BEAMS TO FAIL WITHOUT WARNING.
Consequence:
AN UNEXPECTED LOSS OF LOW BEAMS COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT THE HEAD LIGHT SWITCH AND COUPLER FOR SIGNS OF HEAT DAMAGE. IF HEAT DAMAGE IS PRESENT, THE DEALER WILL REPLACE THE SWITCH AND COUPLER. IF NO HEAT DAMAGE IS PRESENT, THE DEALER WILL REPLACE THE HEAD LIGHT SWITCH AND ONE MATING PIN IN THE COUPLER. OWNER NOTIFICATION BEGAN ON APRIL 5, 2004. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
dlric
17
Apr 15, 2016 03:36 PM
Jeannoel
20
Dec 18, 2014 06:05 PM
maclarry2004
Lighting
Apr 24, 2008 10:11 AM
2000si
Feb 17, 2003 10:49 AM
