01' prelude SH drivers side axle seal part #?
I have a leaking drive shaft seal on the drivers side. This is an SH model so it does have the ATTS unit. I do not have the car with me, its at my buddies house. I do not remember if the axle goes into the ATTS unit or not. I just need the OEM # please for that seal.
Thanls
Sid
Thanls
Sid
No sir, but thank you anyway. We found it. The drivers side axle plugs into the ATTS unit as does the passenger side as well. There is a inner oil seal and then an outer axle seal. I need both.
Parts #'s are for item #13 91203-P6K-003 Inner oil seal. Item #14 91260-SR3-003
Thank you again. You can see the items under the ATTS unit components.
Sid
Sid
