Tps problems
So I can't seem to find any help anywhere with my tps problem. I fixed my tps for a day, I bought a new sensor from AutoZone and replaced it and calibrated the voltage to the proper setting. I did the ecu reset cel Is gone (o2 sensor is throwing cel) along with the 4-2 gasket on my header. Day later I check the codes again cause it started tps symptoms again along with a small exhaust leak coming from the 4-2 in my header which I just replaced. I don't know where to go without throwing money at it when it could be super simple. Any help would be perfect thanks guys.
csunny95
Sep 20, 2018 10:15 AM
teg01type-r
Mar 7, 2007 08:02 PM
