2000 Integra GS-R Ignitor (ICM) Removal???
Old Nov 30, 2017 | 11:28 AM
:jdmshmaydm:'s Avatar
Icon4 2000 Integra GS-R Ignitor (ICM) Removal???
Sup guys I’m trying to replace the icm on my 2000 GS-R. I researched online and multiple sources state there are 2 screws holding the ignitor to the dizzy. However on my B18C1 I saw only one.
I unscrewed the one screw (a wire bracket) but the ignitor is still jammed in there. Am I missing something to slide this piece out? Here’s a pic,
The part is a little banged up cause I’ve been smacking it with a hammer and using pliers to try and pull it out. Do I remove those 2 screws to the left of the icm? I watched a few tutorials and the 2 screws are just beneath the module, not on the other side like the pic.
Old Nov 30, 2017 | 12:06 PM
MotorMouth93's Avatar
10 Year Member
Default Re: 2000 Integra GS-R Ignitor (ICM) Removal???
The distributor isn't difficult to reassemble, just unscrew more **** around it until you can see what's still holding it in there.
Old Nov 30, 2017 | 04:46 PM
tamboo's Avatar
10 Year Member
dude you definitely shouldnt have to smack anything.
will pm you a link to the helm shop manual lol.
it should be attached to a heat sink which is
bolted through the dist housing.
Old Nov 30, 2017 | 06:23 PM
tallguy's Avatar
Two 7mm bolt on the side .. comes right out.
Old Dec 1, 2017 | 10:31 AM
Thank you!
jdmDAsix
Oct 21, 2004 10:17 PM
0bd1_Kanobe
May 2, 2004 01:06 PM
6GACCORDH22
Mar 22, 2003 03:31 PM
