Honda Civic 98 1.4i, 66kw peculiar starting problem
Old Nov 30, 2017 | 07:09 AM
Avo Kukrus's Avatar
Icon5 Honda Civic 98 1.4i, 66kw peculiar starting problem
HI. The car stood for one and a half months, started for a couple of seconds, but because the powersteerings pump's strap was loose, I shut it down and tightened the strap.
The next day when trying, the starter drives the motor around, but does not start.
* The ignition candles have spark, I tried all the candles against the engine.
* I cleaned the candles, the gap is 1mm.
* There were gasoline on the candles, and when the ignition was turned on, I felt pressure in the gas hose, so I assume there is pressure.
* The start-up liquid was also sprayed under the air filter.
Startups are with crocodiles from another car, because the battery is empty.
car ca 280t. traveled, belt changed 200t.
What else to check?
corey198807
Jun 25, 2011 09:33 AM
kikacha
Jun 28, 2007 03:14 PM
kikacha
Jun 25, 2007 01:43 PM
