Honda S2000 Honda S2000
s2000 maximum amount to skim head
Old Nov 22, 2017 | 04:21 AM
Burnie's Avatar
Default s2000 maximum amount to skim head
engineering company have skimmed 18 thou off head?
Old Nov 22, 2017 | 07:35 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: s2000 maximum amount to skim head
That's a lot... have a Cometic head gasket made that is .018" thicker than stock to make it up. Problem solved.
Old Nov 23, 2017 | 04:35 PM
Chance EG's Avatar
Just make sure your P2V clearance is good. And like JR said, you can always get a thicker aftermarket gasket that can make up for the difference.
Also note that your compression ratio is going to be higher with that much milled off the head, unless you compensate with a thicker gasket.
driftingdonuts
Jun 2, 2011 02:30 AM
barhonda_delsol
Honda S2000
Nov 3, 2009 01:24 PM
slo_hatch
10
Jan 31, 2008 08:35 PM
