D16Y8 How does a head gasket "blow"?
Old Nov 19, 2017 | 10:22 PM
LSteggyguy's Avatar
Default D16Y8 How does a head gasket "blow"?
It seems like a MLS head gasket can't exactly blow unless metal actually is lost. But when I removed my head gasket, all the material seemed there. On D series engines is a "blown" head gasket really just a warped head?
I have a D16Y8 with 200k miles on it that had exhaust gas getting into the water jacket, I replaced the head gasket and really nothing changed. I changed the head gasket again and put a junkyard head on it and it seems to be holding alright
The original head looks ok, and I used a straight edge and it seemed straight enough. Think the head is ok? Does it need a resurface at the machine shop?
Old Nov 19, 2017 | 10:29 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: D16Y8 How does a head gasket "blow"?
Did you actually measure it or did you just eyeball it? What kind of straightedge?
Old Nov 19, 2017 | 10:37 PM
LSteggyguy's Avatar
kind of eye balled it. I used a long ruler and set it along it's thin edge, not the flat face, but the thin side of the ruler
Old Nov 19, 2017 | 10:41 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Was the straight edge longer than the head itself?
Are you checking it per the FSM and using feeler gauges to verify how flat it is? One cannot simply eyeball it....
Old Nov 19, 2017 | 10:46 PM
LSteggyguy's Avatar
yes, it's longer than the head.
Not checking per the FSM And not using feeler gauges.
I'm just really wondering if the head warps on these D series engines and the head gasket doesn't actually "blow"
Has anyone just replaced their "blown" head gasket without resurfacing the head and everything is all good?
Old Nov 19, 2017 | 11:18 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
When you torque down the head, the gasket crushes and seals between the two mating surfaces.
If you don't resurface the head, the area where it has warped is still there. It will leak again, soon, if not right away, because it is not going to seal.
Old Nov 19, 2017 | 11:21 PM
tony_2018's Avatar
Fish Twig
He didn't use a straight edge, he used a ruler.
Old Nov 19, 2017 | 11:24 PM
GIZZ - EXV's Avatar
Loved
We would always send heads out for checking, pressure test and milling, until one day we sent one down to the machine shop. They were really busy, they put a straight edge on it and sent it right back with our driver saying all good and no charge. After that we bought a straight edge(real deal in a wooden box) and out of the last maybe 100 head gaskets only sent out maybe 2 heads to the machine shop and that was just because the tech was paranoid and being extra cautious.
It it was run a long time with a bad gasket, or seriously overheated I'd pay close attention with the straight edge.
But in regards to your orig question, a machine shop could pressure test your original head. But that costs money, I wouldn't bother. Or just flip it on it's back and fill the chambers with atf yourself and see what happens. I'd probably just chuck it in the dumpster.
Old Nov 20, 2017 | 04:13 AM
mk378's Avatar
When you take apart, you should see marks on the old gasket and the head or block where the gasses were blowing through. If you don't find that kind of failure, really investigate the head and block for cracks.
Another common problem is corrosion of the aluminum head or block that eats into the "fire ring" seal area. That will require replacement or rework by a machine shop.
Old Nov 20, 2017 | 01:46 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You seem to be forgetting about the thin Viton rubber layer of the MLS gasket. It's that rubber that fails over time to "blow" a head gasket.
Old Nov 20, 2017 | 02:48 PM
tony_2018's Avatar
Fish Twig
Thin layer of it too. But as long as both surfaces are true it shouldn't go again.
Old Nov 20, 2017 | 04:10 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
I use a ruler as a straight edge all the time, but it's a Mitutoyo
Old Nov 20, 2017 | 05:43 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The one I just got is Starrett, ground to within .0001"
Not sure if that going to be accurate enough.
Megalodong's Avatar
There is no "seem" to it. You measure flatness with a straighte-edge and feeler gauges by measuring in multiple directions and if you can push a .004" or greater feelr gauge between the head and straight-edge it needs to be milled flat. A properly post milled head should be .002" or less. Your engine's cylinder head most likely warped at a location(s) between the coolant jacket and cylinder.
Read: AGCO Automotive Repair Service - Baton Rouge, LA - Detailed Auto Topics - Symptoms of a Blown Head Gasket
Checking for flatness:
Old Nov 20, 2017 | 05:44 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Oh you fancy!
Old Nov 21, 2017 | 05:00 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
https://www.youtube.com/watch?v=HyKN52HD6RU
The key not mentioned here and shown so wrong in the video is you use a precision straight edge not a ruler. A ruler can have variances of .01" no problem which will give false readings all day long.
Originally Posted by Caoboy
Oh you fancy!
It's all that is available to me locally. Mitutoyo would have to be ordered online. But I'm pretty sure Mitutoyo has the same specs.
Old Nov 27, 2017 | 09:19 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Which model/length did you get, TomCat? I've got some head work with a straight edge I've got to do in the coming months. I could use your feedback. Thx.
Old Nov 28, 2017 | 08:26 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Sorry @deschlong, I actually posted it in GDD in the latest purchase thread, but that thing grows sooo fast. I was a little off the precision but it's still plenty accurate enough at 0.0002" per foot.
I bought the 24" as I figured two feet should be long enough to go diagonally across the blocks or heads I'm testing. Might get a longer one down the road but think this should do for now.
Old Dec 1, 2017 | 07:18 PM
Megalodong's Avatar
De-******* is going to do head work?..lol
Old Dec 2, 2017 | 02:34 PM
deschlong's Avatar
Loved
Community Favorite
Icon6 Re: D16Y8 How does a head gasket "blow"?
de-******* likes to get head work done, it's true
Old Dec 2, 2017 | 04:49 PM
tony_2018's Avatar
Fish Twig
Likes to get head
driftingdonuts
Jun 2, 2011 02:30 AM
hb_guy
Oct 14, 2005 11:52 PM
new_to_hondas
May 20, 2003 07:46 AM
boostedel
Apr 6, 2003 09:11 AM
