best setup f23a1
Old Nov 17, 2017 | 10:22 PM
HAccord1998's Avatar
Post best setup f23a1
Whats the best pistons, rods, crank and cam to get 9:1 compression and about 350 - 400hp, fuel injectors etc??
Old Nov 19, 2017 | 12:07 PM
GhostAccord's Avatar
Default Re: best setup f23a1
Not going to get 350-400hp without boost. So you need rods and pistons that will support forced induction. Stock crank is fine. Cam, one that has been tested to make 350-400whp with boost. and injectors will also be based on boost level and Hp. There are a number of companies that make good quality 1000cc injectors that will work with the F23 and a tuneable ECU.
On that subject, what are you planning to use for tuning? Do you have a tuner already in mind? If so, I would refer to him/her for the best setup for them to help you achieve your goals. $$$$$
PhatBoy5015
Jul 7, 2006 04:34 PM
tics
May 16, 2006 06:32 AM
the DA in HONDA
Sep 1, 2004 08:55 PM
jrponline
Jul 5, 2004 06:56 PM
