Help
Old Nov 10, 2017 | 06:33 PM
Djfox's Avatar
Default Help
My 1993 civic will not start. It dose spin over but will not fire. I changed the main relay but did not help also i dont hear the fuel pump either. I was going to replace it but instead of the normal 12.5 volts going to it there was only 0.5 so wtf is wrong with it please someone help me. I just put alot of money in the front end of the car an would like to drive it back an forth to work.
Old Nov 10, 2017 | 07:35 PM
mk378's Avatar
Default Re: Help
Turn key on but don't crank. The oil and battery lights should come on. The check engine light should come on then go out. The main relay should click on when the key is first turned, and click off when check engine goes out. (During the time it is on, fuel pump would run).
Old Nov 10, 2017 | 08:24 PM
egsleepercivic's Avatar
Default Re: Help
you replaced the main relay with a new one or known working unit ?
If so test voltage for the fuel pump wires at the relay, hopefully someone can tell you the colors
if good there start the pump or relay work your way back or forward and see if you can find a break or test voltage at any connectors
did you check for spark ? can you here the fuel pump prime?
if you in central Florida i got a pump you can test with
gl
Old Nov 10, 2017 | 09:00 PM
Djfox's Avatar
Default Re: Help
gl
main relay is new an the fuel pump will not prime an i do have spark. The last time the car started i had to leave the key turn on for 45 seconds before it prime but after that nothing now.
Old Nov 10, 2017 | 09:50 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Help
Sounds like bad power capacitors in the ECU. Try another computer.
Old Nov 10, 2017 | 10:00 PM
Default Re: Help
ok im a little buzzed but i am gonna try to help .....
before when it would prime after 45 secs that was before the new relay ?
I gonna llok for my helms to see if I can figure out which wires go to the pump from the relay so you can test at the relay to see if you getting 12v there
how did you check for voltage at the pump ? did you remove the connector from the pump and test ? or was still connected ?
I think you should be able to run wires straight from the battery to the pump to test... but you might want to wait for someone else to chime in before you try that
how many miles on the pump ? original ?
Old Nov 11, 2017 | 12:28 AM
Djfox's Avatar
Default Re: Help
yes 45 secs before new relay an we did check volts at relay an it was fine an fuel pump was checked still connected. An i had the car for 11 years an i believed its the original
Old Nov 11, 2017 | 12:41 AM
Default Re: Help
remove the connector from the pump and check the voltage
Old Nov 11, 2017 | 01:24 AM
Djfox's Avatar
Default Re: Help
[QUOTE=egsleepercivic;51474785]remove the connector from the pump and check the voltage[/QUOT
i will try that man thanks.
EJ8CIVIC
Jul 7, 2015 03:47 AM
beatngyou27
10
Nov 4, 2013 08:18 AM
jerome^galon
Jan 4, 2012 07:03 PM
PatrickFrantz
Aug 21, 2008 05:53 AM
Lsweez
Jun 28, 2007 10:08 PM
