Valve cover only problem?
Old Oct 26, 2017 | 04:32 PM
Moo Sid's Avatar
Default Valve cover only problem?
So I just got a 91 honda civic lx. Old car but I'm trying to learn some things. I have smoke coming from the tail pipe and oil in the spark plug wells. Going to change valve gasket cover spark plugs and spark plug wires. Does this sound right to Do?
Old Oct 27, 2017 | 03:05 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Valve cover only problem?
Yes, a good place to start to remedy oil in the spark plug tubes, however doubtful that those will improve the smoking coming from the tail pipe. How many miles on the car? If the smoke looks/smells like burning oil, it is likely oil is getting into the cylinders, but not through the spark plug tubes. Could be getting past the rings or past the valve guides/seals.
Old Oct 27, 2017 | 09:28 AM
Creator's Avatar
Replace your PCV while your at it. It is usually the reason the valve cover starts to leak.
Old Oct 27, 2017 | 01:12 PM
Doodasi's Avatar
a stuck pcv valve can also make it burn oil like a pig.
Old Oct 30, 2017 | 09:26 AM
94eg!'s Avatar
#1 Super Guy
Loved
Step one is replace the PCV and valve cover grommets. If that doesn't fix the problem, step 2 is much more involved. You need to replace the 4 spark-plug-tube o-rings between the head and the cam caps by removing the complete rocker assembly. It can be done without removing the timing belt, cam-gear, distributor or head, but you ABSOLUTELY need a valve-adjustment afterward.
As long as you don't REMOVE the cam-cap bolts, the 80+ parts that make up the rocker assembly will stay together as one unit.
You should be able to see where the leak is coming from looking down into the spark-plug-tubes. If oil is coming from the top, then it should be a valve-cover-seal. If it's coming from only halfway down, then it's a cam-cap o-ring.
relentlesstech
12
Feb 3, 2014 07:56 PM
turboteg90
Oct 9, 2007 04:53 PM
honda4674
Nov 2, 2005 08:09 PM
Hey Whats Up
May 5, 2005 04:46 PM
quazar
Jun 22, 2004 06:46 PM
