Fuel pump 95 accord 4 cylinder manual
Old Oct 19, 2017 | 10:07 PM
Scarletta's Avatar
Default Fuel pump 95 accord 4 cylinder manual
Replaced fuel pump . But will not start what do I do
Old Oct 20, 2017 | 05:46 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Fuel pump 95 accord 4 cylinder manual
Why did you replace the fuel pump in the first place?
Have you verified fuel pressure?
Spark at the spark plugs?
Unrestricted air flow to the engine?
Cam shaft belt is not broken?
Old Oct 21, 2017 | 03:08 AM
Scarletta's Avatar
Icon7 Re: Fuel pump 95 accord 4 cylinder manual
Di dnt hear the pump build pressure check fuse and pgm fi relay that s ok. I'll check high pressure line or what would suggest first most common reason for no start. Before I changed it it would start and immediatly die. Solo what's you thoughts
Old Oct 22, 2017 | 10:17 AM
angrysmileyface's Avatar
Failed ecu or faulty main relay
Old Oct 22, 2017 | 02:31 PM
MAD_MIKE's Avatar
MM Gruppe B
Did you check for battery voltage at the fuel pump electric connector?
If no or low voltage there is a problem with the wiring or the power to the main relay.
Just because the main relay clicks, does not mean the contacts are still good. Verify power to the pump first.
Old Oct 28, 2017 | 07:40 AM
KINGPETE's Avatar
Icon6 Re: Fuel pump 95 accord 4 cylinder manual
Did you check/replaced all the fuel filters, I think there is more than one. Worth trying !! It could very well be the reason you replaced the fuel pump to start with. Good luck !!
Old Oct 30, 2017 | 01:27 PM
holmesnmanny's Avatar
have you actually checked for fuel or are you guessing ? if you got fuel, then check for spark using a spark tester
Dxvid
May 2, 2019 02:05 PM
wteebo
Sep 2, 2014 03:00 PM
zcmotor
30
Mar 17, 2008 05:53 PM
whitehf
Aug 6, 2006 01:22 PM
JDMlyfestyle
25
Oct 16, 2004 11:05 AM
