Fuel pump 95 accord 4 cylinder manual
MM Gruppe B
Re: Fuel pump 95 accord 4 cylinder manual
Why did you replace the fuel pump in the first place?
Have you verified fuel pressure?
Spark at the spark plugs?
Unrestricted air flow to the engine?
Cam shaft belt is not broken?
Di dnt hear the pump build pressure check fuse and pgm fi relay that s ok. I'll check high pressure line or what would suggest first most common reason for no start. Before I changed it it would start and immediatly die. Solo what's you thoughts
MM Gruppe B
Did you check for battery voltage at the fuel pump electric connector?
If no or low voltage there is a problem with the wiring or the power to the main relay.
Just because the main relay clicks, does not mean the contacts are still good. Verify power to the pump first.
Did you check/replaced all the fuel filters, I think there is more than one. Worth trying !! It could very well be the reason you replaced the fuel pump to start with. Good luck !!
