itr susp. on ef
Old Nov 11, 2002 | 03:26 PM
lsvteceg's Avatar
Default itr susp. on ef
just wondering if anybody here has done this. Also wondering how hard this would be? and what kind of modifications would have to be done if any.
[Modified by whitecivac18, 12:26 AM 11/12/2002]
Old Nov 11, 2002 | 03:29 PM
poison's Avatar
Default Re: itr susp. on ef (whitecivac18)
I believe the front's will go right in, for the back, however you will need to get ITR lower control arms because the strut sits on/inside the control arm and is slightly shorter than an EG's, EK's or EF's (in your case) due to it being slightly lower and stiffer suspension.
You might want to reconsider, though because the ITR's weigh about 2500-2600 lbs, and your ef weighs max 2200 lbs, so if you were to drive around with itr suspension, you'd definitely be 4x4ing everywhere.
Old Nov 11, 2002 | 05:24 PM
ULTRA911's Avatar
Default Re: itr susp. on ef (poison)
the rear is the one that will fit fine, no need for a itr lca for the rear in the EF. the front, might need the itr or gsr tie rod. there's a lot of topic about this, do a search.
RED_90TEG
Dec 20, 2007 12:15 PM
Egezzy
Jul 27, 2005 07:44 AM
hatchlessrex
Jul 12, 2004 03:06 PM
red civic standard
Jan 19, 2004 06:08 PM
