Quick question, b18b or b18c non-vtec
Old Oct 17, 2017 | 09:54 AM
darmstro's Avatar
Default Quick question, b18b or b18c non-vtec
Looking for my next race car project, but rules state VTEC must be disabled, so what would be the faster of the two? A non VTEC integra or a GSR with VTEC disabled? I searched, didn't see any power numbers for the b18c with VTEC disabled (for obvious reasons, lol)
Old Oct 17, 2017 | 10:59 AM
CandyRedRC46's Avatar
Default Re: Quick question, b18b or b18c non-vtec
Obvious reasons? Click this ----> LMGTFY
Old Oct 17, 2017 | 12:28 PM
tony_2018's Avatar
Fish Twig
Find an engine with no vtec then....
Old Oct 17, 2017 | 01:47 PM
darmstro's Avatar
I'm talking about a stock motor that simply has VTEC disabled.
Old Oct 17, 2017 | 02:27 PM
tony_2018's Avatar
Fish Twig
you are confused at what you want.
Old Oct 17, 2017 | 07:51 PM
darmstro's Avatar
No I'm not. I'll reword it. Is a GSR Integra with the VTEC solenoid unplugged still faster than a GS/RS/LS b18b Integra. This is for a racing series that doesn't allow cars with VTEC or any variable valve timing, unless it's disabled.
Old Oct 18, 2017 | 04:41 AM
Hurr durr.
Old Oct 18, 2017 | 01:21 PM
MotorMouth93's Avatar
10 Year Member
I doubt anyone here knows because just unplugging the VTEC solenoid on a stock motor/stock ECU and expecting good results is retarded. The engine isn't built to run that way in stock form and the results will show it.
VTEC heads do *typically* have bigger valves and flow better than non-VTEC heads, so if you're looking to do an actual "vtec killer" build then you should start your research there, there is plenty of documentation on those builds if you look for it.
Old Oct 18, 2017 | 08:32 PM
darmstro's Avatar
Thanks for the reply. Not looking to build anything, was just wondering if searching for a GSR would be worthwhile.
I​​​​​​ ran a Sentra SpecV this year with the vvt solenoid unplugged and it didn't make a difference in lap times, wasn't sure how the B18C would work...
Old Oct 19, 2017 | 04:26 AM
Long story short, VTEC engagement on a GSR is at 4400 RPMs from the factory and the secondary butterflies in the intake manifold open at 5750 RPMs. Technically you could buy a GSR, leave the engine/ecu/intake manifold stock, unplug the VTEC solenoid (disable VTEC or lock it or whatever tf you have to do to stay in VTEC all the time), leave everything else alone and it would probably run shitty from idle to 4400 and then be normal above 4400 to red line. In a race you shouldn't be below 4400 RPMs anyways, so if you know how to drive, a stock GSR locked in VTEC should be faster than a Stock LS. It would probably idle with some cam lope and maybe be a pain in the *** to start, not positive on this, but probably. Hell, maybe it would be fine and only suffer minor loss in low end, idk, but if you could tune the mapping, it would definitely be a plus and run a lot better.
Old Dec 28, 2017 | 01:07 PM
Zace's Avatar
Following. I have similar rules in my state for hornet racing, and I have a bad cylinder in my b18b1.
Old Dec 29, 2017 | 04:22 AM
AYB18c's Avatar
This option would probably make the most sense. Lock the VTEC to "engaged" at all times so you're running off of the high cam lobe. Power will be off below 4400 rpm, but since you're racing you should be above 4400 at all times.
A GSR in VTEC, above 4400rpms (where it's supposed to be) will be faster than a stock b18b
Old Jan 2, 2018 | 05:46 AM
This is probably all going over his head.....
iNDyCRX
Dec 15, 2007 12:25 PM
7andaswitchblade
Jun 20, 2006 09:33 PM
beandip
14
Feb 11, 2003 04:48 PM
Vtecivic99
Dec 13, 2002 07:53 AM
1hotintegra
Sep 10, 2002 02:46 PM
