Anyone know how to get this clip out?
put a pair of vice grips on it at the top and yank it up and off
this is all it is https://www.google.com/search?q=brak...ake+hose+clips
It is that easy. Just use a flat head screw driver to pry between the folded top edge of the clip and the shifter box housing. You can attack it at an angle from the sides and/or directly from the back and "twist" the blade to raise the clip. Once it is high enough, you can place the blade of the screw driver through the slot in front and pry (against the cable directly behind the clip) straight up to remove the clip fully.
