2001 Integra GSR fuel cut off
Hi I have a 2001 Integra GSR it starts and runs fine but when you get higher in the rpms or you are flouring it the fuel cuts off and it try to and or dies. can anyone help with what might be causing this issue. PLEASE! I threw a code for a crank pos sensor so I changed that out after that is when I started having this issue. it currently has and obd1 hondata ecu in it. it will not start at all with the original ecu it throws a code for fuel cut off.
Are you sure it's fuel and not your ignitor or coil going bad? Do you have a fuel pressure gauge?
I would change fuel filter and check grounds first. Then check coil and ignitor with a ohm meter.
I'm pretty sure it's fuel there's nothing till you shift n even then sometimes you have to shut her down then restart. No I don't have a pressure gauge. I've changed my fuel filter n spark plugs put in new wires. All the grounds are good and I've checked the cap n rotor seem fine.
weirdone86
Sep 14, 2006 07:35 AM
