B16a2 Pistons Rods upgrade
Old Sep 29, 2017 | 11:41 PM
Type 56's Avatar
Default B16a2 Pistons Rods upgrade
How much power gained if i were supposed to rebuild my current stock B16a2 motor with just aftermarket like JE pistons and Manley rods? Supposed those were the only parts that i replaced during the rebuild, how much power increased would i gained from those 2 parts alone??
Old Sep 30, 2017 | 04:00 AM
Chance EG's Avatar
Default Re: B16a2 Pistons Rods upgrade
Rods don't increase or impact power, just what power is safe to push to.
Pistons won't change much by themselves, and it's also important to consider what the compression of those pistons is which you don't have listed right now.
Old Oct 1, 2017 | 05:41 PM
Type 56's Avatar
Then how do one increased power by working on the internal part of the motor without going boost?
Old Oct 1, 2017 | 06:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Increase displacement, increase compression, increase camshaft lift and duration, larger throttle body, quality header, larger exhaust pipe diameter, increase intake manifold plenum volume, and CNC cylinder head work will all help make more power naturally aspirated.
GT500FTW
Sep 6, 2015 01:32 PM
civic-r11
Jan 28, 2009 06:33 PM
jdmjeff
Feb 14, 2005 01:16 PM
Edward
Apr 13, 2004 10:14 PM
JsNA99si
Apr 8, 2004 06:07 PM
