1996 Civic HX strange v-tec solenoid mounting surface
Old Sep 26, 2017 | 11:36 AM
dondajunk's Avatar
Default 1996 Civic HX strange v-tec solenoid mounting surface
Old Sep 26, 2017 | 11:38 AM
dondajunk's Avatar
Default Re: 1996 Civic HX strange v-tec solenoid mounting surface
Old Sep 26, 2017 | 12:03 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Are you talking about the rectangular slot to the left of the bottom bolt?
That's not an opening. It's a casting indentation. It's not your leak source. Get a mirror and look at it. You'll see what I'm talking about.
Make sure you replaced both the filter gasket and the upper gasket on your solenoid. Clean the surfaces before you reinstall.
Here's a picture for reference
CX-Adam's Avatar
talks to himself
Community Builder
ok... looks like OP deleted posts while I was answering.
Old Oct 2, 2017 | 06:24 AM
dondajunk's Avatar
Thanks for the reply! I replaced the solenoid and cleaned the area. the oil was leaking out of that Port looking part of the cylinder head casting. I found another thread on B20vtec that covered this issue where others had found the head casting cracked in that area. Anyway, I used high temp Quick steel metal epoxy and so far so good !
Proud Virginian
Jun 20, 2022 06:59 AM
SaltyDog017
27
Feb 24, 2012 02:56 PM
awps
Sep 29, 2005 08:19 PM
kin_8
Jul 9, 2004 05:41 PM
Farnsrocket
Feb 3, 2003 07:27 AM
