Help with OBD location
Old Sep 18, 2017 | 12:49 PM
secur60's Avatar
Default Help with OBD location
Hello every one i have a Honda civic coupe 1998 ej6 d16y7
well can some one help me to find the obd location i searched all over the car and couldn't find any thing
here is a photo for the fuse box
wheil other 1997 honda has it here
thanks in advance
Old Sep 18, 2017 | 08:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Help with OBD location
It should be clipped into the rectangular port/cut-out that you see clearly in your first photo. You may have to remove the fuse box and search behind to find the plug... or it may be higher in the front of the dash. More searching will be necessary.
Old Sep 19, 2017 | 03:30 AM
NVturbo's Avatar
O.G. triple O.G.
Previous owner definitely relocated the OBD2 port. Should still be in the area. Just have to look
Old Sep 19, 2017 | 05:31 AM
secur60's Avatar
do you have any idea where shall i start from
the obd wiring diagram for example
it shouldn't go too far
Old Sep 19, 2017 | 05:41 AM
civic402lx's Avatar
Start top left corner of your first photo. There is some kind of plug there. Look there and work around the fuse box.
Old Sep 19, 2017 | 06:48 AM
Michael Mendoza's Avatar
That small blue connector looks like my OBD 1 connector. Is it possible he made it OBD1 ?
Old Sep 19, 2017 | 07:55 AM
NVturbo's Avatar
O.G. triple O.G.
OP, on your pic....left of the fuses, you will see a rectangular opening. That's where the OBD port is supposed to go. Check there. Not sure why anyone would remove it, even if the car was to have an OBD1 engine setup.
No, it doesn't work like that.
Old Sep 19, 2017 | 11:40 AM
secur60's Avatar
i spent almost 30 minutes in that tiny place searching for it well i have seen things .. horrible things and didnt find any thing
there were a Bunche of cables with a note assemble in Mexico
here is a video too
Old Sep 21, 2017 | 08:12 AM
secur60's Avatar
today i took out the dash in front of the fuse box and here is what i found
no OBD 2
just some mystery disconnected ports
Old Sep 22, 2017 | 03:11 AM
NVturbo's Avatar
O.G. triple O.G.
One thing no one seemed to ask.....is the car a USDM? If not, YOU don't have one.
Old Sep 22, 2017 | 06:06 AM
secur60's Avatar
You mean a car made in USA well there us a plate under the hood said it was made by Honda America in Ohio
Its imported into Germany from USA
So if it is so
What does that mean
Whata the difference and us there any way to make a connection
Thanks in advance
Old Sep 22, 2017 | 08:04 AM
NVturbo's Avatar
O.G. triple O.G.
So if it is so
What does that mean
Thanks in advance
Your car is designated for the German market. Even though it's assembled in the states, emissions was set for that country. That is why you DO NOT have an OBD2 port.
Old Sep 22, 2017 | 10:06 AM
secur60's Avatar
damn dude
why the hell they took it out
and inst there any way to make a connection ?
Old Sep 22, 2017 | 03:09 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
damn dude
Did you verify if your car is USDM or CDM?
Old Sep 22, 2017 | 10:50 PM
secur60's Avatar
Good morning
Wel​​​​​​l it seems to be USDM
so one last thing to ask
Is not there any way to diagnose the ecu for a USDM Honda ?
Old Sep 23, 2017 | 02:02 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Okay, it appears the chassis is USDM as per the VIN you posted:
So now, we can fairly confidently assume someone removed your OBD2 scanner port/plug. It is disturbing that your check digit is 0 and not 7 as per the decoder.
No if someone can provide photos of the obd2 port and harness to show where it runs to, that would be ideal to help you find the harness junction.
Then again, someone more knowledgeable may point out my assumption is incorrect and that it is not a CDM or USDM car. It's manufactured in the USA, but was it for a different market then imported? I do not know how to check that. That check digit bugs.....
Old Sep 23, 2017 | 02:30 PM
secur60's Avatar
Dude you have mistaken with the number there is I instead of 1 after the W
1hgej6140wi601188
Btw whats the different between usdm and others
Old Sep 23, 2017 | 04:14 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Lots of things, Europe OBD2 is a different protocol than North America and JDM used a totally different Honda proprietary diagnostic service and possibly port. And is why OBD2 scanners that have Euro protocol in them are more expensive than your most basic CDM/USDM obd2 scanners.
And it can't be an I as per the decoder:
VIN:
1HGEJ6140WI601188
Warning: VIN has invalid check digit (9th character). Make sure it is spelled correctly! (check digit = X, found = 0)
Decoding error: VIN contains illegal characters: I, O or Q. Make sure it is spelled correctly!
And just so you know, posting your VIN allows someone to goto Honda and order a key for your car. Then they just have to figure out where you live and bye-bye car.
I will edit my photo's if you like if this is a concern to you.
Old Sep 23, 2017 | 05:25 PM
civic402lx's Avatar
Honda dealer will requires proof of ownership before cutting new key off the vin. Im sure some "other" center will do it without proof. Anything is posdible, i guess.
Old Sep 24, 2017 | 02:39 AM
NVturbo's Avatar
O.G. triple O.G.
USDM cars DO NOT have that green plate in the engine bay.
Old Sep 24, 2017 | 07:50 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
So maybe the concern was for stalking?
I remember everyone always said posting your full VIN was bad.
In this case, it's not a USDM or CDM VIN so seems like a moot point....
Old Sep 24, 2017 | 10:23 AM
civic402lx's Avatar
True. Any info, personal, posted on the interweb is bad. Never know who's watching.
Old Sep 24, 2017 | 11:46 AM
secur60's Avatar
well i don't know what shall i do now
and at the registration papers there is another letter not I nor 1
so back to or point if its now a USDM or CDM what the heck is this car
any one here lives in Europe has a 1998 civic ?
Old Sep 24, 2017 | 11:49 AM
secur60's Avatar
btw i dont know how things going in US but how other ppl gonna benefit from cars VIN
Old Sep 24, 2017 | 01:56 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Honda had cars in more than just Europe, there is New Zealand, Australia, Japan etc etc.
Each one is it's own domestic market.
Your dealership might be able to help you identify it with the VIN as I mentioned in PM.
