Hasport cable to hydro bleeding problem
Old Sep 17, 2017 | 05:20 AM
dnxracer's Avatar
Default Hasport cable to hydro bleeding problem
Hey guys so I can not seem to get the air completely out of clutch line it's a ys1 cable trans in my ek and I've bled and bled but still can't get all the air out the pedal will not return all the way up it'll go halfway and then I have to pull it the rest of the way with my foot I installed the kit correctly I've checked twice I'm cracking my hard line on space to bleed it because they say the bleeder will not work to get air out but the clutch pedal doesn't even have any pressure until a little over halfway pushed down so I can't even put car in gear so any thoughts would help thanks!
Old Sep 17, 2017 | 07:29 AM
mk378's Avatar
Default Re: Hasport cable to hydro bleeding problem
There should be a spring on the pedal to push it all the way up once it is halfway up. The pedal needs to come all the way up every time for the clutch to bleed properly.
Old Sep 18, 2017 | 12:59 PM
dnxracer's Avatar
Bump please
Old Sep 18, 2017 | 08:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Did you bench bleed the clutch master cylinder ???
Ricextacy
Jan 18, 2012 09:12 AM
Kannan08
Transmission & Drivetrain
Oct 23, 2011 11:17 PM
Kannan08
Oct 13, 2011 02:32 PM
som3on3_10
11
Dec 25, 2004 12:47 PM
GreenMachineRex
May 4, 2004 06:22 AM
